Error uploading a file to cloud storage
ja--hu
ja--hu
Hi from Germany,
I'm having a major issue with my Fusion 360 program, and I was hoping someone could help me.
An error occurred while saving a file. Now, the program is stuck in the cloud, which slows it down and prevents me from setting my files to read-only. This means that I can't create any new projects.
I only save to the cloud.
I have already emptied all caches and prefetch folders. I uninstalled the program and ran a registry cleaner.
Even after reinstalling the program, the same problem persisted after logging in. Here is a video of the problem.
Unfortunately, I can't get any support because I'm a freeware user.
dsouzasujay
Hi @ja--hu ,
Follow below steps and see if the problem gets fixed.
  • Close the Fusion application.
  • Please back up the folder mentioned below and delete all the files under W.login?
  • If you are unable to delete the files, you might need to restart your machine.
C:\Users\[YOUR USERNAME]\AppData\Local\Autodesk\Autodesk Fusion 360\[YOUR OXYGEN ID]\W.login
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
ja--hu
Perfect! Thanks a lot!
