Error: Failed to schedule cloud solve while doing an event simulation study
I was solving a simulation and i got an error message: Failed to schedule cloud solve. I've never had this problem before and I have no idea about what makes this happen. After I failed to do this simulation, as a test, I did a simple static stress study, like applying tensile force on top of a box. This study can be solved locally, but I got same error message when I did it on cloud. How can I fix this? I attached diagnostic logs below.
pawel.potyrala
Hello @Anonymous,
thank you for posting and for sending over your diagnostics log files. I was able to find the following reports in all of your application log files:
"W PROXY: failed to query IE proxy configuration - ǁ·Ͻà"
Are you able to test if the cloud solve works when you're connected to another network? We collected some possible solutions to network-related issues in the following knowledge article:
Troubleshooting Network Connectivity Issues for Autodesk Fusion 360
Thanks in advance!
Please accept as solution if my post resolves your issue, or reply with additional details if the problem persists.
Best regards,
Paweł Potyrała
Technical Support Manager
Global Product Support
My Screencasts | Fusion 360 Webinars
well..actually I forgot about this post. I don't know why but it just resumed. Thank you for your concerns!
