error 403 when accessing accounts.autodesk.com and get sign in failure on Fusion
gman9500
Message 1 of 8
gman9500
Hi I'm not exactly when this started as I haven't logged into fusion 360 for almost 2 weeks(Sick) but now I get sign in failure on 2 computers(One win10 home and one Pro)
and can't access any of the support links or accounts.autodesk.com  links except via work laptop
(Work laptop does not have fusion 360)
I get error 403 and something about cloudfront from 4 different home computers when I try to post to this forum or access my  account on the web
ONly on my work laptop(via same router but over work vpn) can I post to this forum or access my account
Time is synced correctly on all 4 computers.
I restarted router
I tied deleting the login xml script and did a clean uninstall and reinstall and I still get  sign in failure on home laptop
Did comcast suddenly start blocking  autodesk?
I don't know what changed or why I suddenly can't access autodesk websites from home or what is blocking fusion360 from signing in
Replies (7)
Message 2 of 8
karina.harper
Autodesk Support
Autodesk Support
Hi @gman9500
I've seen this a few times this week from folks from security companies such as Neustar.
You can reroute your DNS to go through a public domain like google as a workaround, and I would recommend requesting an exception if that is an option.
Let me know if that works,
Karina
Message 3 of 8
Thanks, that did not work. I changed the dns to 8.8.8.8 on both my laptop and even tried it on my router. Where do I get this exception from?
Message 4 of 8
karina.harper
Autodesk Support
Autodesk Support
Hi @Anonymous
Hm, interesting. Can you take a screenshot of the error you're seeing? In Fusion and on the web?
Karina
Message 5 of 8
gman9500
Hi Karina, sure
Here  are 3. Taken with phone and then uploaded to my work laptop as that's the only way I can sign into the forum. When I try to sign in to the forum from any home computer\laptop. It's blocked with the same 403 Error.  Also attached
Message 6 of 8
karina.harper
Autodesk Support
Autodesk Support
Hi @gman9500
I think this must be it:
https://aws.amazon.com/premiumsupport/knowledge-center/s3-website-cloudfront-error-403/
If cloudfront is blocking you, then I think you'll need to create an exception.
Cheers,
Karina
Message 7 of 8
gman9500
Hi Karina, how or where do I an create an exception?
I looked at the TCP /ip setttings on my computer and didn't see a place. I beleive I can do one on my  browsers but thats not going to help logging into Fusion 360
Incidentally I get same issue when trying to log into Tinkercad
Daryl
Message 8 of 8
karina.harper
Autodesk Support
Autodesk Support
Hi @gman9500
You'll need to reach out to cloudfront our your network service provider. This article may have more information.
Cheers,
Karina
