Loft profiles don't display when editing feature
I created a part without any errors which uses a loft. When I open the Loft to edit it, either one or both of the profiles used to create it aren't visible. I cancel out of the feature edit window and the part reappears without any errors. I also closed both the file and Fusion 360 and reopened without any change. Does anyone have an idea what's happening or how to make the profiles appear in the feature edit window?
Fusion 360 version 2.0.6670, Mac OS Catalina version 10.15.1Loft feature window does not display profilesLoft feature window does not display profiles
ryan.bales
Autodesk Support
Autodesk Support
Unfortunately your screenshot cuts off the most important part of visibility questions - the browser. Are sketches and or that sketch shut off?
Ryan Bales
Fusion 360 Product Support
The sketches are visible in this screenshot, but the profiles still don't appear.
ryan.bales
Autodesk Support
Autodesk Support
Man i was hoping that would trigger something. We will need to see the file, could be a defect.
Ryan Bales
When trying a workaround, I opened up the sketches in the file which are the sources of both profiles.  The Loft feature window now populates.  If nothing else changes, consider the problem solved.
