I'm trying to model a crown. For the top of the head band I want to add some "filigree". I'm trying to use pattern on path to copy a cut/sweep feature around the top of the band. while i'm in the edit feature mode for pattern I can get things previewing correctly but once I click OK the features get all bunched up and/or incorrectly rotated.
I tried simplifying & starting a test file of just the process I'm trying to achieve & it still doesn't work (https://a360.co/2FYrmTV)
no matter what i do it doesnt seem to work -
Is it the compound curve/elipse causing the issue?
is there a different process i should be using?
