Edge display error?
Edge display error?
alexi_creecy1
Edge display error?
alexi_creecy1
Model displays as having peeling, mesh like, edges with obvious holes along the models perimeter. It seems to be a purely visual display error, as once the file is exported to STL or STEP it's watertight. However I'm not sure if this is poor modelling on my behalf, or a Fusion error.
This model was created with a sculpting mode loft command followed by a number of extrusions and fillets around the edges.
Attached screen shots, one as seen normally, the other in cross-section analysis.
Cant upload the actual file as its for a friends design.
saito.kh
Autodesk Support
Autodesk Support
Hi @alexi_creecy1,
Thank you for posting and welcome to the community!
Sorry to hear that!  At this moment I suspect there might be something related to graphics in Fusion with this design.
In order to take a closer look at this, would you mind sharing the design with me?  If it is okay with you and your friends, can you please send a public link to the design - see this web page for how to share a design, and send it to me ([email protected])?
If you have any questions, please let me know!
Thanks.
Kanehiko SAITO
Product Support Specialist
Fusion Webinars | Tips and Best Practices | Troubleshooting
alexi_creecy1
Thanks for your reply.
Strangely the error seemed to sort itself out, once I added a fillet to a few surrounding edges.
saito.kh
Autodesk Support
Autodesk Support
Hi @alexi_creecy1,
Thank you for the update!
Good to hear it was sorted it out at this time.  I do imagine there might be something related to graphics with the geometry.  If you can share a design you are experiencing this issue, I would appreciate your sharing it for the further investigation of this!
If you have any questions or concerns, please let me know.
Enjoy Fusion!
Kanehiko SAITO
saito.kh
Autodesk Support
Autodesk Support
Hi @alexi_creecy1,
Thank you for sharing the design with me!
Sorry to hear this is happening.  I suspect there might be a very tiny object in the space.
I will take a look at this on my end (with my colleagues) and get back with you once I have something to share!  Thank you for your patience.
Thanks.
Kanehiko SAITO
jimmy.wick90
Clear browsing history and cached data
Clearing this cache will sometimes fix page display problems. If you can open Microsoft Edge, select Settings and more > History > Clear browsing data. Select All time under Time range; select Browsing history and Cached images and files, and then select Clear now.
Jimmy
