Dynamic pattern along a path
lesliejr01
lesliejr01
I am trying to create a pattern of holes along a path or circle and have the path or circle a dynamic value. The pattern feature will create the holes along the path just fine but when the dynamic value for the path is adjusted the hole pattern remains the same.  Is there a way to make the hole pattern move with the path or circle.  Thank you for any advice.
jhackney1972
Here you go.  Change the Diameter of the Circle and the Pattern Count in the Parameter table.  I used a circle but the process is similar on a path length.
If this answers your question, please select the "Accept Solution" icon on my post. If you have further questions, please ask.
John Hackney, Retired
lesliejr01
Yes, that is what I am doing except the diameter of the circle changes but the pattern does not move with the circle.
jhackney1972
Attach your model and we can see where your issue lies. If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section, of a forum post, to attach it.
lesliejr01
Sorry this may help
lesliejr01
Model is attached
jhackney1972
Your model has been modified to do as you ask.  Your method of placing the holes has to be changed because they were not taking the path diameter.  The video will explain. The Pattern_Count will affect all pattern hole count, easily modified if needed. Model is attached.
