DXF exporting problems - Pieces of Lines / Splines
Message 1 of 8
I'm trying and trying to EXPORT DXF from a body
normally : right click on face - sketche - project - select face choose square or solid - you get a sketch - right click and export to DXF
The DXF I get is only pieces of splines/lines
(I tried : to restart fusion - to project solid - from body, from sketches)
To show you :
short video
Long video
Thanks for help
Replies (7)
Message 2 of 8
ryan.bales
Autodesk Support
Autodesk Support
Hi @Anonymous,
You probably need to DXF Spline to Poly line addin to make sure you are getting the cleanest export from Fusion.
It could be an issue with exporting the projected geometry as well but I would try the add in first.
Ryan Bales
Fusion 360 Product Support
Message 3 of 8
rohit.bapat
Hello @Anonymous,
Sorry to know that you are facing this issue. The problem that you mentioned in the Long Video Link is actually caused due to double projection problem. It is a known issue and we have been working on it recently. Once it is fixed this problem will be automatically get solved and you will no longer see double/overlapping entities in dxf.
One workaround I can suggest is to create an Offset plane parallel to the desired surface and then try projecting the face/body onto it. This way you can avoid multiple projections.
Offset Plane WorkaroundOffset Plane Workaround
Again, sorry to know you are facing this issue but, we are working on it. Please let me know if you have any questions.
Thank you,
Best Regards
Rohit Bapat
Rohit Bapat
Sr. Product Owner
Message 4 of 8
thank you @ryan.bales
It help for 1 thing : No more lines/splines that hide others
... but I still don't have a unique spline for my complete shape...
Message 5 of 8
hi @rohit.bapat,
Thank you
Well I tried what I was able to understand from your animated gif
no difference BUT
I'm not sure that I did it well.
Some parts of your animated gif is hided...
Would like to ask you so :
Could you take time and do a vid with the same thing but complete screen please ? 🙂
Message 6 of 8
rohit.bapat
Hello @Anonymous
Sorry for the trimmed gif. I was trying to show the offset plane thing. But, you are right some parts are hidden that may cause confusion. Here's the full window gif.
Just to explain what I did
I created a body
Clicked on Offset Plane
Created an offset plane with zero distance from upper face
Created a sketch on this plane
Projected face onto this sketch (plane)
I hid bodies and original sketch to avoid ambiguity while analyzing the projected sketch.
Tip:
At end of the video I am long clicking the curve i.e. keeping the curve left-clicked for a bit longer. This way I confirmed the list of items I have underneath my cursor (selected). This technique can be used anywhere in the sketch for geometries, constraints etc.
This is a workaround to avoid multiple projections.
I hope it was useful. Please let me know if you have any concerns.
Thank you,
Best Regards
Rohit Bapat
Rohit Bapat
Sr. Product Owner
Message 7 of 8
thanks @rohit.bapat for yourvery clear video 😉
I always tear my hair with the export of my files ...
I make a little video to be certain that you can check if I make a mistake ...  youtube video
Really a pity that I can not export the body, to send it to you, to share more easily its files ... It is detrimental to people who like me need help.
Message 8 of 8
rohit.bapat
Hello @Anonymous
I went through the video you have created. According to me, there is nothing wrong in the steps you took.
One thing that I think is not currently supported in Fusion is that in the exported dxf the connected curves do not get exported as a single spline. I believe our Ideastation  is the right place to put forward this request/idea.
But, just out of curiosity, how will a single spline (outline) in the exported dxf be used in your workflow?
Thank you,
Best Regards
Rohit Bapat
Rohit Bapat
Sr. Product Owner
