dxf corrupt and exploded when sent to auto cad
Message 1 of 14
Hi
I have recently started using Fusion 360 and am having a few problems
1 - files keep either being scaled by 10x or -10x when importing and exporting.
2 - when I have exported the files to dxf all the components jump around and lines don't meet up. This means they need completely re drawing by our CNC tech
3 some of the dxf's are 'locked' so are once exported cant be edited, measured ect ect
Replies (13)
Message 2 of 14
g-andresen
Explain what the exported DXF should be used for.
In the screenshot I see a 3-D structure.
What should your CNC colleague develop from it?
günther
Message 3 of 14
Hi
I am designing sofa frames in 3D, each flat panel or timber rail I am making as a separate component with in the file. when I send it to the frame tech he opens it in Auto Cad and it has loads of bugs, is corrupt or wrong scale.
flat panels need to be CNC'd.
thanks
Message 4 of 14
g-andresen
I think the Arrange tool should do what you want.
günther
Message 5 of 14
Hi
thanks for the help, looks like a cool useful tool but not not really what I was looking for. I wanted to be able to draw a frame and send it as a 3d model for the cad tech to be able to take the components he needs for cnc. when I send the file the lines jump everywhere. I sent a flat dxf but when he opened none of the lines were connected or where i drew them. any sugestions?
thanks
Jake
Message 6 of 14
TheCADWhisperer
And Attach resulting dxf files that exhibit the behaviors that you describe and the dwg files after import might be useful too in diagnosing the issues.
Message 7 of 14
g-andresen
@Anonymous  schrieb:
... 3d model for the cad tech to be able to take the components he needs for cnc.
This is exactly what he gets when you use the Arrange tool.
günther
Message 8 of 14
if you look at the model compared to the first picture, the panels have gone mental and jumped from original position
Message 9 of 14
TrippyLighting
Can you share your original Fusion 360 model in .f3d format ?
Message 10 of 14
attached
Message 11 of 14
HughesTooling
One of your problems is using "Auto project geometry on active sketch plane". When you have this enabled and you sketch on a face all edges are projected into the sketch
Then when you copy and move the component you get something like this. This is component 26 but you have others, the shaded area is from the edges of the plane you sketched on.
Mark Hughes
Owner, Hughes Tooling
Message 12 of 14
Ok thanks, that helps!! will i have to re draw everything with feature off or will turning off delete edges projected into sketch?
any clue on scale issue?
Message 13 of 14
HughesTooling
You'd need to edit the sketches and delete the curves forming the profile. You will only need to edit one of the copies, just double click on an edge to select the whole path. You will then need to manually project in a point to constrain the sketch if you where using the profile before.
You can actually select and delete without editing the sketch but don't leave the sketch unconstrained.
Mark Hughes
Message 14 of 14
HughesTooling
On the Scale, all cloud exports are done in CM, the units are set in the DXF so the program opening them should be able to convert to whatever units you need.
Mark
Mark Hughes
