Color Swatch
Color Swatch
donraylacer
Color Swatch
donraylacer
I imported an OBJ file and cannot figure out how to turn off the Color Swatch. The color swatch gear does not appear in the lower right-hand corner and therefore I cannot figure out to turn it off, i.e., change to the gray color of the Fusion 360 components. Any help would be greatly appreciated.
jeff_strater
I don't think that is component color cycling.  You can try turning it off here:
But, most likely, this is Mesh Face Group coloring, and you can turn that off here:
Jeff Strater
Engineering Director
donraylacer
Thanks, that solved the problem. I tried everything that I thought would cause it, but didn't even consider it to be a mesh problem.
