Drawings: Problem Updating Drawing Links with flat pattern
I am working in a drawing file made from a template that I normally use. First I finished my model file, then I created the drawings. The problem started with a sheet metal component that I forgot to generate the flat pattern, in the drawings it appeared a red box indicating a problem (this was automatically generated by the template). So I returned to my model file, I generated the flat pattern of that component, then when I return to my drawing file, it says something about files are corrupted, and now I can't update my drawing anymore, the update button is not working and the "not update alert" appears.
I have tried deleting those views, even deleting the complete page. Also I have tried making some changes to the model and saving a new version. Nothing works.
Fusion 360 is an incredible program by the way!
saito.kh
Autodesk Support
Autodesk Support
Hi @Anonymous,
Thank you for posting and welcome to the community!
I am sorry to hear that trouble is happening.  May I take a closer look at the file on my end?
If it is okay with you, can you please share a public link to the file with me? - you might like to send it via my PM.
This link guides how to share a design file.
If you have any questions or concerns, please let me know.
Thank you.
Kanehiko SAITO
Product Support Specialist
Fusion Webinars | Tips and Best Practices | Troubleshooting
Hi Kanehiko,
Thanks for the answer! Shure I send you the link.
Hi once again Kanehiko,
I tried re-making my template file and then using in the same model and then following the same process of the file with problems. This time it works correctly and the flat pattern updated. Thank you anyway for answering!
saito.kh
Autodesk Support
Autodesk Support
Hi @Anonymous,
You're welcome!
I am glad to know you were able to resolve this issue.
Thank you and enjoy Fusion!
Kanehiko SAITO
