Drawing Space won't load
TrademarkCreative
TrademarkCreative
I'm trying to make a technical drawing of an assembly.
(attached) But the drawing space crashes on load.
Basically,
(1) I open my part
(2) Then I try to make a new drawing from the design
and it crashes.
Here's the error message. Clicking 'ok' does nothing. I wait for hours, nothing. Only way to close is kill it from task manager.
Based on what this is saying, it looks like some of the experimental scripts I have going may be breaking things.
Thoughts?
jhackney1972
Whatever it is preventing your from creating a 2D drawing, it does not seem to affect my system.  Drawing develops just fine.
John Hackney, Retired
TrademarkCreative
darn. That's the drawing I want.
I'm going to delete all my experimental plugins and see what happens.
jhackney1972
If you want to try, here is the F3Z file that contains the 2D drawing.  Be careful and not pollute your existing work.
TrademarkCreative
Ok. I think I got it.
By deleting the add-ons I had and then clearing the cache.
This post talks about how to clear the cache
https://forums.autodesk.com/t5/fusion-360-api-and-scripts/can-not-remove-add-ins/td-p/9892571
I can now load the Drawing Space. hurray.
@jhackney1972 thank you for your attention to this.
jhackney1972
If you are satisfied with your forum question, please do not forget to Accept Solution so others can find the help they need on a similar topic.
