Differing Drawing Templates in the same Drawing File
jon.hobsonDXEF8
Observer Observer
jon.hobsonDXEF8
Observer
Observer
Is there a way in Fusion 360 to use differing templates within the same design file? We have created a front sheet template & a general sheet template. Within the same design file we want to use the Front sheet template on sheet 1 and then the general format on subsequent sheets.
g-andresen
YES
Follow:
günther
Phil.E
This should be possible using Fusion drawing templates.
First, please read the help section with all the details about templates and drawings:
http://help.autodesk.com/view/fusion360/ENU/?guid=GUID-7D66F0CF-97BD-4EFB-9EB2-37CF89F76C56
When you use File > New Drawing Template you can define a template with as many different sheet styles as you need. In this image I created a simple example, The first sheet has no title block, the second sheet has the default title block, and the third sheet has it's own unique title block. There is no limit to the number of sheet styles and title blocks you can use in a template.
Have you tried this?
Phil Eichmiller
Software Engineer
Quality Assurance
jon.hobsonDXEF8
Observer
Observer
Thanks, that's worked a treat 😀
