Designs show up invisible
sparky122sparks
sparky122sparks
Hello everyone, I had to load a file I hadnt opened in a good while and the body is entirely invisible. Ive tried toggling the bodies and component views but nothing seems to bring it back. Any idea on what could be causing this issue?
jhackney1972
Attach the model so the Forum users can look at it.  Hard to tell from a picture.  If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section, of a forum post, to attach it.
John Hackney, Retired
sparky122sparks
Sorry about that, I should have attached this.
jhackney1972
Your model did not attach.  You cannot attach it from email, you must come back to the Forum post.
sparky122sparks
Attached fully this time
jhackney1972
It happens to all of us one time or another.  You have an Active Section Analysis that is in front of your model.  Turn it off to see your model.
sparky122sparks
This fixed my issue, thank you!
