Mouse scroll no longer zooms in MacOS
nicolasdYC5D7
Observer Observer
Message 1 of 17
nicolasdYC5D7
Observer
Observer
I use a Mac mini M2 Pro with a Magic Mouse and the new version, Fusion 360 2.0.16753 no longer zooms when I use the "scroll wheel" on my mouse.
With the new version, the scroll wheel only pans up and down or side to side. I can't find a way to use modifier keys to zoom in and out with the mouse. With the old version scroll up and down would zoom (I forget which way).
What I have:
Fusion 360 2.0.16753 arm64 [Native]
Plan actif: Personnal
macOS 13.5 (22G74) on Mac14,12
Magic Mouse 2nd generation
Replies (16)
Message 2 of 17
SHEENA.SUKYXQC
same here
Message 3 of 17
nicomtl
Just to add to my original post:
Not being able to zoom using the scroll wheel makes it VERY annoying to use the Drawing Workspace: If I zoom in using the magnifying glass and want to zoom out, I can't. I have to close the drawing and reopen it so it opens at full page view. 😕
Message 4 of 17
lance.carocci
Thanks for the report. I have identified this issue to be specific to the Magic Mouse's touch surface. For some reason, Fusion is getting trackpad touch events back from the OS rather than mouse events.
The quickest workaround for the moment would be to utilize a traditional 3-5 button mouse, as this is not reproducible with a scroll wheel.
This issue is logged as FUS-133609
Lance Carocci
Fusion QA for UI Framework/Cloud Workflows, and fervent cat enthusiast
Message 5 of 17
jctfjcwy
Please help fix it ASAP, I do not have a traditional 3-5 button mouse standby
Message 6 of 17
lance.carocci
Hi @jctfjcwy, could you please try try unchecking Use gesture-based view navigation in Preferences? This will also disable gestures for the trackpad, but will serve as a workaround until the issue can be resolved.
Lance Carocci
Message 7 of 17
nicomtl
That worked for me! 🙂
Message 8 of 17
jctfjcwy
Work only once, after I click other area and hide some items
Then it does not work again
Message 9 of 17
jctfjcwy
I have restarted and confirm it does not work for me
Fast D go fix it and it is VERY annoying
Message 10 of 17
harryreslan67
Just to add to this: @lance.carocci use gesture-based navigation solution worked for me!
Very annoying thing to troubleshoot, I must say. No issues with this happening before. I use a Mac Studio with magic mouse, common denominator = Magic Mouse. Similar to above, traditional mouse is not an option. This works for now, hopefully it doesn't affect anything negatively going forward!
Cheers
Message 11 of 17
knut9C3JU
That worked for me, but now I have lost the ability to rotate the view. I used to just hold down ctrl-key and I could rotate the view. Now the only option is to use the view cube. I think this almost as bad.
Message 12 of 17
chromo.light
Same problem here.
Lost zoom, followed the workaround to turn off 'gesture based view navigation', then lost pan and orbit.
What the heck?
Message 13 of 17
jctfjcwy
When you guys repair the fix? It is taking tooooooo long
Message 14 of 17
fusion360EP98K
Same issue here 😞  Mac Studio with apple mouse.  Macos 13.5.2  Fusion
360 2.0.16985 arm64 [Native]
Message 15 of 17
andreas.scheucherautodesk.hobby
Guys, the main input device is already since more than 2 months not working for nearly all of your Mac users!
Do something!
Message 16 of 17
lance.carocci
@andreas.scheucherautodesk.hobby this issue applies specifically to Zoom with Gesture-based Navigation enabled on the Magic Mouse. Are you experiencing a general failure of all app input?
Lance Carocci
Message 17 of 17
thanks for reaching out. No, after turning off gesture based it worked again.
sorry, was frustrated, as i wanted to do some construction fora project and first fusion didn’t show the file panel in the left.
tried to uninstall and install again, but after removing it was still there.
it turned out I copied over my user folder from another computer including the library folder. Search indexing picked up the fusion installation from the backup. Took some time to figure this out.
had to delete it, reinstall it. Hence, I lost two hours I would have had a time slot to work on my hobby project after that I couldn’t use fusion anymore, as my mouse went amok…
long story short, it works again. Thanks.
