Decals not showing up in renderings all the sudden.
Local renders. No, it's not a normals thing, we use templates to render third party branding onto products. Did I accidentally toggle something off? No file renders right now.
I don't see an option in the render menu to turn them off.
I swear its a new issue every other day with this software. 😕
jodom4
Hey variant1,
Can you share an archive so we can take a look?
Jonathan Odom
Community Manager + Content Creator
Oregon, USA
Become an Autodesk Fusion Insider
Now its working all the sudden, except all the renders I queued after toggling a different label on (typically, there are multiple SKUs), have all rendered as the first label.
Any plans in actually finishing the software?
Basically, I've got to shut the software down entirely every time I change or add a label and reopen it or I get a render with no label on it. Man Mad
The company is going to switch to Keyshot here soon and I cannot wait. I'm so tired of playing Russian Roulette with which feature won't work right on any given day.
lucasproko
Hey @Anonymous,
I'm sorry to hear you're having issues with our rendering workspace. I understand there's a big frustration when things don't work how you expect them to, and I can assure you, our focus moving forward is on reliability.
That being said, I'm curious for a bit more information on the problem you're describing. In my tests, changing decals, and then creating new renderings results in the behavior I would expect. Namely, each new rendering correctly displays the decals that are present when the rendering is queued. Could you elaborate a bit more on your exact workflow so I can try and replicate it?
Also, are you using Cloud renderings, or Local renderings?
Lucas Prokopiak
Fusion 360 Product Manager (Sketch/Model)
britdizzy
I've been having the same issue with decals being there and rendering fine, then they disappear. the decal is still present, and when you select it, it shows as a blue square, but will not show when in the design or render space. I have replaced decals, and the same thing happens over again.
@lucasproko
hope you can help.
hotlipsporter
Community Visitor
Community Visitor
I'm having the same exact problem. Decals have been showing in renders no prob and then all of a sudden, nothing! Come on Autodesk, you guys gotta come up with a solution for this...enough people are having the same issue. There isa bug!
