Decal not showing in shaded view
perW789Z
perW789Z
I have used decals and shaded view in drawing mode as a tecnique to show models an easy way with a photo background. This worked fine up until a couple of weeks ago. 02.03.2022 last time used. Now it does not keep or import from model the decal in shaded view anymore. Model size seems not to be the problem. Anyone know if this possibility have been removed?
g-andresen
I cannot confirm the error.
please show the process in a screencast
günther
perW789Z
https://autode.sk/3I3dTGS
Here are the screencast link. I would apperiate if you could solve this problem for me.
Regards Per
g-andresen
On which component and on which side is the decal located?
Please share the file.
File > export > save as f3d on local drive  > attach it to the next post.
günther
perW789Z
I managed to solve the problem myself. It has something to do with image size in bytes or maybe some information contained in the image file. I put the jpeg file trough PIXresizer and stored it at the same ratio and frame size. I can see that the file loses approx 300byte in the process. Original size 1.4Mb. new size 1.1MB. Now it works flawless. Have made several drawings now. All need to go trough the pixresizing process to work and some of them are over 1.4Mb and still works??
Maybe you now the explanation or limitations for this in fusion? Anyway i am happy and get on with my work. Thank you for the effort!
Regards Per
