French translation errors
Francois_Moreau
Advisor Advisor
Francois_Moreau
hello, this thread for asking corrections about translations errors in Fusion software and online help.
in this thread , @patrick.emin  recommand to post here
https://forums.autodesk.com/t5/fusion-360-francais/fusion-360-comment-proposer-une-suggestion-d-amel...
and this thread is unfortunately closed
https://forums.autodesk.com/t5/fusion-360-feedback-hub/closed-fusion-360-in-french-and-italian/td-p/...
So I hope this is the right place,
some captures with proposals
Services publics         do not mean anything,  "Utilitaires" other "Outils" much better.
Position de la capture      mean the oppposite of what must be " Capturer la position "
Curseur     mean cursor, "Rectiligne" much better
Rainure de goupille      mean nothing   Better like " Curviligne"  even the original "Pin slot" is better
Fibre neutre  mean neutral fiber do not help , "Plan milieu" much better
Supprimer   two times not possible,  " Retirer" is the correct word
I hope thoses proposals can go up to the developers
(thanks again for the general good quality of the French version)
François Moreau
bénévole sur le programme Expert Fusion:
patrick.emin
Thanks @Francois_Moreau I will forward this to the team.
Patrick Emin animateur de la communauté francophone
Vous avez trouvé un message utile? Alors donnez un "J'aime" à ce message!
Votre question a eu une réponse satisfaisante? Voulez vous avoir l'amabilité de cliquer sur le bouton
 APPROUVER LA SOLUTION  en bas de la réponse qui apporte une solution?
Signez notre Livre d'Or
Francois_Moreau
about Joint
I find this on Wikipedia
  • lower pair joint
    • revolute joint : liaison pivot,
    • prismatic joint : liaison glissière,
    • cylindrical joint : liaison pivot glissant,
    • screw joint : liaison hélicoïdale,
    • planar joint : liaison appui plan,
    • spherical joint : liaison sphérique (rotule) ;
Maybe better to use them
"Glissière" for slider
"pivot glissant" for Pin-slot
François Moreau
DavidManivelle
@jodom4 @patrick.emin
Hi folks,
An other translation detail in the drawing view properties box:
"Précédent" means "previous". use the word "derrière" instead.
Francois_Moreau
Other "Arrière"  like the name of this face on the Viewcube , but it's right "précédent" do not help.
François Moreau
