Cutting object makes them all short?
pingthehood
Message 1 of 13
pingthehood
Sorry for the bad title, I'm working on a basic shed model, the back end of the wall is 2.4M tall, and the front end of the wall is 2M Tall, so i want a sloped roof, i made the struts up, then made them all 2,4M tall, then i was going to just cut the angle, however when I cut the angle it made the angle but also made all the lumbers short?
How do I cut the roof?
Replies (12)
Message 2 of 13
TheCADWhisperer
@pingthehood
Are all of your sketches fully defined?
Message 3 of 13
pingthehood
Here "Link" it wont let me sent it directly
Message 4 of 13
davebYYPCU
The four studs in the side wall should be individual (Copy /Paste New) components.
Cut them with your sketch and then Pattern the duplicates.
Might help....
Message 5 of 13
TheCADWhisperer
@pingthehood
Your first sketch is missing two dimensions and one geometry constraint.
When I add the missing dimensions and constraint - observe the red lock symbol on the sketch.
Also observe that the unconstrained sketch geometry has changed color.
The second sketch does not appear correct.
I drag the endpoint of the short line from image above to connect the rectangle and add the missing dimensions.
I would have modeled with symmetry about the Origin and Mirror Component rather than copy and move body...
The third sketch is missing a dimension and when I add the missing dimension the current geometry size does not make logical sense (that is one reason we fully define all sketch geometry).
Sketch4 appears to be empty.
Sketch 5 is missing a dimension and a position constraint.  When I add the missing dimension, it does not make logical sense.
Sketch 6 is missing a constraint (or dimension, I would use constraint).
Sketch8 is missing a Constraint or dimension.  If I dimension - it does not make logical sense.
Sketch15 is missing a dimension and appears to be way off.
Another sketch that appears to be off...
This is Sketch16.
Message 6 of 13
pingthehood
How would I do that? like make them separate without moving them again?
Message 7 of 13
TheCADWhisperer
@pingthehood
I do not see this cut in the file that you Attached?
Message 8 of 13
pingthehood
No i removed it just before saving, its literally a sketch on that upright strut and drawn to the angle of both, and extruded to cut/boolean.
Message 9 of 13
TheCADWhisperer
@pingthehood
I could see from the picture what it was, but I was looking for more information about your Design Intent before demonstrating how I would model the geometry.
Message 10 of 13
pingthehood
Im not sure, im quite new to Fusion 360, and simply cutting an angle is harder than i thought.
Message 11 of 13
davebYYPCU
Don't have to cut them if you use Extrude to Object.
See if this make any sense.
Message 12 of 13
pingthehood
Just looking at the picture i have no idea, but i will look at the model soon.
Message 13 of 13
TheCADWhisperer
@pingthehood
One simple sketch (see Attached).
