custom threads not showing up in the menu
maxime.loiseau
maxime.loiseau
I am trying to add a custom thread file, but it is not appearing in the thread menu of Fusion 360.
I followed this tutorial: https://knowledge.autodesk.com/support/fusion-360/learn-explore/caas/sfdcarticles/sfdcarticles/Custo...
I located the \ThreadData folder, pasted the custom thread file (.xml), and then restarted Fusion 360. However, when I opened the thread menu, nothing happened.
Thank you
jhackney1972
Could you attach your XML file to allow others to check your syntax.  Also we can try it out also.
John Hackney, Retired
maxime.loiseau
I found the file here : https://www.printables.com/fr/model/247411-photo-thread-library-for-fusion360
This is custom threads designed for photogragy equiments.
jhackney1972
I downloaded the TXT file you directed me to, changed the Extension to XML and added it to the Thread Database folder, restarted Fusion 360 and it shows up fine.  I would re-trace your steps to verify your process is exactly as outlined in your first posted link.
maxime.loiseau
I have identified the issue. Yes the path is %localappdata%\Autodesk\webdeploy\Production<version ID>\Fusion\Server\Fusion\Configuration\ThreadData.
However, there are two <version ID> folders that contain a \ThreadData folder with the same path.
(The wrong \ThreadData folder contain nothing inside)
