BUG - 2d circular pattern edit button unreachable
nigel76FS8
nigel76FS8
Just downloaded the latest update, and, as always, I go to see if this has been fixed, and it never has been. Not in 5 years.
When you do a circular pattern in a sketch, the icon button to edit it is easy to hit if you want, when there are 3 or 4 lines, but the moment you increase the number to enough to be over the icon, you can no longer hit it to double click it!
Anyone know a better work around than using a parameter and editing that instead?
jhackney1972
Hovering over top of the sketch pattern icon you will have an easy time of selecting it if you hold down your left (select) mouse button until you see it in the selection list.  You can then select it with easy and right click your mouse to edit it.
John Hackney, Retired
nigel76FS8
Thanks John. That's a clunky work-around! But at least it solves the issue. The UI team should just move the control to "float" above the lines so it can be selected and double clicked, like any normal UI would do.
