Bug. Offset loses reference.
HughesTooling
Consultant Consultant
HughesTooling
I was trying to fix a model for a customer based on an ellipse with offsets created on a projected face. The problem is if the face is modified before the sketch the offset loses its reference even though I projected the face, not the edge. And because the offset is a spline you end up with something you can't constrain and a broken design. Only option is delete the unconstrained spline and recreate the offset. This of course breaks the next extrude then all the other downstream features.
Here's a simple example, sketch on face, project face then offset projection. Files attached.
Now add a fillet to the edge before the sketch, this breaks the offset and leaves a unconstrained spline that no longer updates and can be moved. Surely the offset could be made to pickup the projected face edge.
Thanks Mark
Edit. Even if i use an edge, after using manage lost projection to reselect the edge it breaks the offset. With the face I can sort of understand it could be difficult to pickup the new edge but if I'm reselecting an edge the offset should not break.
Mark Hughes
Owner, Hughes Tooling
Phil.E
This example is a little easier to interpret. The face is projected, but the offset only operates on the prior curves.
Steps taken:
1. Made a box
2. Offset a work plane and projected the box face
3. Offset the box face loop
4. Rolled back timeline and added fillet
5. Rolled timeline to end of model
Result: the fillet created a new edge ID for the projected face. It wasn't consumed by the offset sketch operation.
Expect: The addition of the fillet should provide a new edge ID to the face, and that should carry thru to the projected loop. But it doesn't.
Reported as FUS-123563
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Phil.E
@HughesTooling Our expectations might be out of line here. It does seem reasonable since the inputs are really straightforward, but I tried it in Inventor and get the same result.
I'll follow up if I hear why this is a special case for sketch offset.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
