Custom appearance rotated?
jesABL6L
Message 1 of 14
jesABL6L
Hi all.. sorry if this has been answered elsewhere!
I am new to F360, just experimenting. I have modelled a simple bungalow, and have created a custom brickwork appearance by importing a jpeg photo. With a bit of scaling, this works well, but with one problem. I drag the appearance to a face, perfect. I drag the same appearance to an adjacent face, which is on a plane slightly recessed from the first, and the appearance is rotated 90 degrees - and vertical bricks just look silly! Any clues?
Thanks!  Jes
Replies (13)
Message 2 of 14
dsouzasujay
Hi @jesABL6L,
I was not able to understand exactly how the appearance looks.
Can you please attach a image, if possible export *.f3d file?
To adjust the appearance, You need to select the body, right click and select the Texture Map controls. They will allow you to modify the orientation of the texture.
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
Message 3 of 14
jesABL6L
I have attached the original jpg which I used, and a screengrab of the result when I drag and drop to the body. It happens the same when I drag to faces instead, which would suggest maybe it's to do with the properties of the faces. The body was constructed from two simple 'barn shapes' which I combined in a sort of T-shape, if that's a clue... I will try to figure out how to export the f3d file.  Thanks for your help!
Message 4 of 14
dsouzasujay
Hi @jesABL6L ,
Did you try 'Texture Map Controls' for the body?
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
Message 5 of 14
jesABL6L
Hello again... eventually found the 'Texture Map Controls', it was by default set to 'Projection Type: Automatic; changing to 'Planar' and playing around with the axes basically just corrupts the appearance display (changes to just horizontal lines).
What I can't understand is, why does it not apply the appearance in the same orientation to faces on the same body? Note:- what I have realised is, the faces of one 'barn shape' are correct, the other 'barn shape' is rotated, even though they are combined into one body. Head scratching continues...
Message 6 of 14
g-andresen
Edit Face Appearance
günther
Message 7 of 14
jesABL6L
Thank you Guenther.... tried that, but it reverses the problem; in other words, the faces that were correct are now rotated, the faces that were rotated are now correct...!
It seems that F360 is applying the appearance consistently (it thinks), but is seeing the actual faces as being in a different orientation for some reason.
I can't understand why, as the two bodies were made via sketch > extrude, sketch > extrude, then combine > join; then shelling the resulting one body. The appearance is applied to that one body.
I am thinking now that I must have gone back and edited a sketch at some point, which has caused the software to become confused. I will go back and start from scratch to see if it is repeatable.
Thanks for your help !
Message 8 of 14
dsouzasujay
Hi @jesABL6L,
Can you please the *.f3d you have created.
It will help us understand.
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
Message 9 of 14
g-andresen
My illustration assumes that the textures have been assigned to surfaces.
They can then be changed individually.
But for each direction a separate appearance must be created.
Screencast
günther
Message 10 of 14
jesABL6L
f3d file as requested...
Message 11 of 14
jesABL6L
Thank you Guenther, that is informative, the screencast is very useful.  Did you make it in F360?
Sorry if I'm being stupid here, I have only been using F360 for a day or so. I'm sure I'll get the hang of it soon!
Message 12 of 14
g-andresen
just download from here install it and create your first screencast
günther
Message 13 of 14
dsouzasujay
Hi @jesABL6L,
You should change the 'Texture Map Controls', with
  • UV Diagnostic Texture
  • Box
Later by applying the appearance you should get the texture
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
Message 14 of 14
jesABL6L
Excellent, that is much appreciated, thank you!
