Critical Issue: Fusion 360 Search Fails to Find Existing Files
joshua_sniffen
Message 1 of 38
joshua_sniffen
Hi Autodesk team,
I’ve been a long-time Fusion 360 subscriber with hundreds of designs stored in the cloud across various projects. I’m now encountering a critical issue that is severely impacting my workflow: the search function fails to return files, even when I enter an exact match of a file name that I can see in the data panel.
I understand (although am frustrated by) the inability to search files with underscores between words, but having files just not show up has cost me a hundred hours this year alone...
Details:
  • File is visible in the data panel under the correct project
  • File name includes the word “camera”
  • Search is set to All Data
  • No filters are active
  • I’ve verified spelling and tried both full and partial match queries
  • The file is not archived and was created directly within Fusion
  • Even after renaming the file, waiting, and re-searching, it still doesn’t appear
  • Web-based Fusion Team search yields inconsistent results as well, but it is MUCH more reliable.
SOMETIMES if I manually find the file, and leave it open for at least 15 minutes, it can be searched again. But it is seemingly random if it will show up next time I need it, months later.
This behavior makes it nearly impossible to manage a growing library of designs. I rely heavily on search for navigating my work, and this issue has reached the point of becoming a serious blocker.
System:
  • MacOS 15.3.2
  • Fusion 2601.1.29 arm64 [Native]
Please advise on how this can be resolved.
Thank you for your time.
Replies (37)
Message 2 of 38
vinayak_dhame
Hello @joshua_sniffen ,
Sorry to hear the issue that you are facing for seraching the files.
It will be helpful if you collect the logs and share it so that we can a look into it.
You can collect the logs and share using the steps given here.
Additionally if you can record a video and share it with us that will also be useful.
Thanks.
If my answer helped, please 'Accept Solution'
Vinayak Dhame
Autodesk Fusion
Message 3 of 38
danS8JRH
I have this same issue. It costs me tons of time to manually scroll through the list. Sometimes I can get it to work if I switch to search all data but not always. It is very very frustrating.
Message 4 of 38
danS8JRH
Here is the diagnostic log and video of the search not finding data
Message 5 of 38
vinayak_dhame
Hello @danS8JRH ,
Thank you sharing the log files and the video.
We will investigate the logs and revert at the earliest
Vinayak Dhame
Autodesk Fusion
Message 6 of 38
johnnyL4KW5
I am also experiencing this issue. Is there any updates on this?
Message 7 of 38
vinayak_dhame
Hi @johnnyL4KW5 ,
Please can you collect the logs and share using the steps given here.
Also if you record a video and share that will be helpful.
Additionally is there anything specific or any special characters used in the file name that you are trying to search?
Vinayak Dhame
Autodesk Fusion
Message 8 of 38
vinayak_dhame
Hi @johnnyL4KW5 @joshua_sniffen @danS8JRH ,
Are you still facing this issue ?
Could you confirm if the result you get when searched in DataPanel and Fusion Web Client are the same.
You can use the below link to login to fusion web client:
https://www.autodesk.com/fusion-team
Once you login,Locate the search icon, at the top right, and click it. Then, enter your search term (file name used for seraching in DataPanel) and press Enter. The results will appear in the main body of the web client.
Vinayak Dhame
Autodesk Fusion
Message 9 of 38
johnnyL4KW5
Data panel on Fusion and Web client both fail to show the item. Name contains alphanumeric and a hyphen. Search is done with alphanumeric only or alphabets only, see videos.
I rarely use the Web Client as it is definitely not my goto when I am looking files/searching for a design as the search is incredibly slow.
Message 10 of 38
CGBenner
@vinayak.dhame
Hello, do we have any update on this issue?  Thanks!
Chris Benner
Message 11 of 38
pecoraro.matt
Observer
Observer
Hi. I have the same exact issue. the file is searchable through the web app but not from the app itself, but if i rename it or move, it return searchable inside the app. this is very annoying.
Any update on this?
Message 12 of 38
vinayak_dhame
Hi @CGBenner @pecoraro.matt @johnnyL4KW5 ,
Thank you for sharing the details.
Our internal Dev team is investigating on this.
Will update here once we get feedback from the team.
Thanks.
Vinayak Dhame
Autodesk Fusion
Message 13 of 38
Debashis_deyN6843
Could you please add me in your hub for some days to investigate the issue and fix as soon as we can? Post that you can remove him.
TIA
Debashis
Message 14 of 38
johnnyL4KW5
@vinayak_dhame  @Debashis_deyN6843
1. GCbenner and pecoraro.matt are not in my hub.
2. Would strongly prefer that you did not share my hub's name in public like this. Please edit your last message to remove the identifying information.
3. I am not admin of the hub and have no rights to share.
Message 15 of 38
Debashis_deyN6843
Apologies and corrected.
Message 16 of 38
CGBenner
@johnnyL4KW5 @Debashis_deyN6843
Good day!  Has there been any progress on solving this issue?
Chris Benner
Message 17 of 38
Debashis_deyN6843
No @CGBenner , we could not reproduce this in our hub.
Message 18 of 38
ritesh_khatri
Hi @danS8JRH ,
Appreciate you for taking some time out to connect with us and discuss your issue.
As we observed, the search in App Home tab in Fusion 360 offers a more complete search than the Data Panel.
We understand this difference can be confusing and are working to align these search functionalities.
For now, we recommend using the Search bar in Project Pivot on the Home tab for your searches.
For more details, you can check the official documentation here: link
Please feel free to contact anytime for any more questions.
Best regards,
Ritesh Khatri
Message 19 of 38
PantechniconDesign
The Data Panel search has never been very good, but it seems to have gotten worse recently to the point of non-functionality.  For us the "-" character in the file name causes the Data Panel search to return no results even when the exact name is searched.  Thanks for posting the instructions for the Home - Project pivot search method, this does return correct results for files with the "-" character, but you really need to fix or delete the data panel search.
Message 20 of 38
ritesh_khatri
Thank you for your feedback regarding the Data Panel search issue with the "-" character and other special characters. We understand the frustration and are actively working to resolve this problem.
We're glad to know that you find the "App Home - Project Pivot Search" method helpful, as it provides accurate and detailed results even for files with hyphens. 😁
Your feedback is very important to help us understand and prioritize our focus on similar issues that are major blockers for users.
Please feel free to reach out anytime if you have any other queries or feedback.
Best regards,
Ritesh Khatri
