Creating code for tapping
jmweng82
jmweng82
  • trying to ridged tap in my chevalier fagor controller  my drilling cycle (drill1) looks nearly same at the tapping cycle (drill2)20220829_212124.jpg
     is this an issue with my post processor not defining the cycle buy creating correct gcode. Thanks
serge.quiblier
Hello @jmweng82
are you sure the toolpath is defined using the correct cycle :
Are you using the correct tool. It should be less critical, but we may use the pitch in the tool defintion for outputting the cycle.
These two factors will orient the post to the cycle.
But the post may be wrong, in the actual library post for Fagor, it is using the classical G84 for outputting the cycle.
So, do you use the Autodesk post from the library? Is it up to date?
If not, update, contact your post provider for fixes....
Cheers
______________________________________________________________
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
Serge.Q
Technical Consultant
cam.autodesk.com
