CREATE DXF OF LASER CUT PART TO INCLUDE LASER ETCHED TEXT?
Message 1 of 8
Hi, hope someone can help - I have created some parts to be laser cut, as DXF file, but need to add some text to parts that can be laser etched. How do I add text that can be etched rather than shapes that will be cut out!
Replies (7)
Message 2 of 8
g-andresen
ask your laser cutter&engraver which data are needed.
Maybe it is a second sketch with special symbolism.
günther
Message 3 of 8
MoshiurRashid
Hi
Thanks for posting. From my experience I don't think the cutting depth or cutting or etching is dependent on the dxf. You just create the boundary in dxf. I would rather create the text and fill the sketch with solid gradient and then rest will be done in cam.
Please contact with the machine operator/programmer and ask him what he need specifically for the text.
Moshiur Rashid
Autodesk Certified Instructor
ACP | CSWE
https://www.autodesk.com/expert-elite/overview
LINKEDIN | FACEBOOK
Message 4 of 8
Figured how to add - pretty simple - just using the add text command from the sketch and selecting a single line font like CDM.shx.
However, when it is saved as a DXF file, it is lost and the border becomes a cut line?
Message 5 of 8
Also, the details required for laser etch are as below:
Did you want a line (vector) engrave, so like the outline of some text or a raster engrave which would mean that the text would be infilled.
  • Vector engraving / scoring:
    • Blue Lines - hairline stroke width - colour: RGB: 0,0,255
  • Raster engraving:
    • Black lines / fills - any stroke width - RGB: 0,0,0
Message 6 of 8
Solved this myself.
For some strange reason, if I actually create the font in lines within sketch, it works fine, whereas using the text function doesn't.
Message 7 of 8
troyostrander
About your solution...so you drew the letters with lines?
Message 8 of 8
g-andresen
1.create text
2. Rightclick  > „ Explode „ >  text is converted to curves
günther
