Crash when switching to Manufacturing
mikeod44A6T
Message 1 of 8
mikeod44A6T
I am running Fusion 360 on MAC Mini M1
The attached file is a the one that cause the crash ... I have run the clean uninstall app and reinstalled Fusion 360 to no joy ...
If its any help at first it worked fine in Manufacturing and I had set all the tool paths, I then added the stars to the design and thats where it all went pear shaped .. I tried deleting the stars but that didn't seem to help ...
Support (who I sent the file to) told me it worked fine on Windows so I am assuming its a MAC / M1 problem
any help would be greatly appreciated
Replies (7)
Message 2 of 8
ryan.bales
Autodesk Support
Autodesk Support
Its not an M1 problem, its crashing on my mac too. How did the problem start? Was it working and you saved/closed and reopened and then it crashed?
Ryan Bales
Fusion 360 Product Support
Message 3 of 8
mikeod44A6T
I drew everything except the 4 stars that are on the drawing and it all worked fine and I made all the tool paths. I then realised I had forgotten the stars ... I edited the drawing in design and then it started crashibg.
I deleted the stars and tried again but it still crashed I rolled back the history and it still crashed which seemed odd to me.
hope that helps
Regards Mike
Message 4 of 8
jhackney1972
It opens in Windows 10 just fine EXCEPT the toolpaths will not re-generate so they are all empty.  I remove the setup and all the three tool operations and save it.  It is attached.  See if you can open it now with the Manufacturing Environment clean.
John Hackney, Retired
Message 5 of 8
mikeod44A6T
Thank you so much for doing that for me. However it still fails which is a real surprise. It does however narrow down where the problem might be 🙂
Message 6 of 8
ryan.bales
Autodesk Support
Autodesk Support
Yeah i'm not sure where its coming from yet, we just logged the ticket yesterday and investigation takes time. But its reproducible and that tends to hasten the process.
Ryan Bales
Message 7 of 8
HughesTooling
Try the attached file. I used "Save Copy As", this strips all CAM data and references from the design.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 8 of 8
HughesTooling
Noticed you have some duplicate lines in your sketch, these might cause problems. Don't know if there are others.
Mark
Mark Hughes
