New version old problem.
mauro.burlon
mauro.burlon
From the insertion of the MESH panel, some files containing the meshes are impossible to open. This update did not solve the problem either.
Version fusion360: 2.0.10446
Apple Mini Mac M1 ( but also with macbook pro intel I7)
MacOs: Big Sur
RajkumarIlanchelian
@mauro.burlon Is it possible to share the design or invite a couple of engineers into your project? If you can invite I can send you the email IDs to invite.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
mauro.burlon
Thank you, i'm share the design, am I attaching it here?
RajkumarIlanchelian
@mauro.burlon you can attache the files here if you are ok with it. If not you can send it to me in a PM too.
Autodesk Fusion
Join Fusion Insider
RajkumarIlanchelian
@mauro.burlon I have received and downloaded your design. Thanks for sharing it. Looking at the issue now with our engineers.
Autodesk Fusion
Join Fusion Insider
RajkumarIlanchelian
@mauro.burlon Once again thank you for providing us the design. I was able to eventually open your design after 2 long hours. I have since then saved the design and PMed you the design. You can right click on your design in the panel and "import new version" and upload the one I sent you. This way you don't have to take the 2 hour impact and your design should continue opening as before. Yes, we are looking into why it is taking 2 hours now to open this design.
Autodesk Fusion
Join Fusion Insider
mauro.burlon
Thank you, i'ts work!
