- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I seem to have 2 documents which can completely crash Fusion 360. I have attached the files for review by the development team. Be warned that they will crash Fusion!
One document (attached as Design1) crashes when I make a change in the file. (It does not seem to mather what kind of change as far as I have tested, otherwise change dimensions in Sketch2)
The other seems to be corrupted and makes Fusion crash just by opening it. (So be warned!) I could still download the file through Fusion team but that did not make a change. When I start Fusion this document shows in the data panel with the rotating bar, i cannot open an old revision.
This one was being worked on simultaniously with Design1. It could be that is was saving when design 1 crashed. It could also be related to the same issue as part of Design2 is a copy of Design1.
Really i'm just reporting a bug here. I do not expect a solution to this. As these are simple models I have not lost much time.
