Countersink hole problems
davidmrosner
davidmrosner
I want to create a simple clearance hole for a metric screw (i.e. m6x1). It seems i have to first select the "tapped hole" option to choose the screw standard and size of m6x1. But the size of the screw diameter, the screw head, and the countersink are all incorrect from the ANSI standard. For instance the hole diameter is 5.035mm and the screw head is 5.539mm.
What am I doing wrong?
Warmingup1953
Why are you opting for tapped hole? You want a 6.5mm Hole with countersunk I assume?...NOT threaded?
g-andresen
please share the f3d file for reply
günther
davidmrosner
Hi - Well thats another issue i have that I don't understand...if i select "simple" which is what i want, then the option to select the screw standard and size goes away. I assumed this was just poor UX design but perhaps its a bug or something stupid i'm doing...
davidmrosner
Here is the f3d file in question
TheCADWhisperer
@davidmrosner
You are creating a Clearance Hole.
Also, your sketches are under defined and best check your dimensions.
Blue curves and white dots should keep you awake at night.
davidmrosner
Hi - That fixed it! Was staring at it too long and didn't realize....
