Stop randomly highlighting faces
FrodoLoggins
Advisor Advisor
Message 1 of 12
FrodoLoggins
Using the chamfer and extrude tools usually [yes usually] results in faces being highlighted. Stop it. Nothing's selected and the top level component has visibility turned off. Fix this. What a jokeScreenshot 2025-04-08 at 8.44.17 AM.png
- Time Magazine’s Person of the Year 2006
- Apple M1 Max rMBP A2485 // Latest MacOS // Latest Fusion
- Usually working off files uploaded to Fusion as: Step, STL, SLDPRT. If it matters ask me.
Replies (11)
Message 2 of 12
Phil.E
Thanks for reporting this.
Logged as FUS-196115.  We'll try to reproduce it, but some details might help. Can you please post the results of your Fusion graphics diagnostic? (not system) I need to see what effects are on, etc.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 3 of 12
FrodoLoggins
[GPU Information]
GPU Device: Apple M1 Max
GPU RAM: 21845 MB
GPU Driver API: OpenGL Core Profile
[Graphics Effects Settings]
Use high-resolution graphics: On
Anti Aliasing: Off
Ambient Occlusion: Off
Object Shadow: Off
Ground Shadow: Off
Ground Reflection: Off
Selection Display Style: Normal
Transparency Effect: Better Display
[Limit effects to optimize performance]
Off
Message 4 of 12
Phil.E
I notice that the selection display style is set to Normal. Can you try turning it off?
I'm just trying to narrow down the factors at play here.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 5 of 12
FrodoLoggins
Changed just this to "Simple":
The highlighted faces that shouldn't be highlighted turned green upon closing the preferences window:
After saving and reopening the file this at least for now is not happening anymore.
Message 6 of 12
Phil.E
Okay, please let me know if the problem goes away. I will include that in the bug report.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 7 of 12
FrodoLoggins
Never changed that setting back, still simple display mode. Just opened another file I worked on this morning and it looks like the chamfer has a different appearance applied [Thumbnail looks normal as it was saved hours ago]:
Shows through when selecting the whole model:
Grey goes away when opening the appearances dialogue, looks like previous light grey highlight:
That grey isn't the black appearance though. Applied the other black appearance to a face and it's a different black:
Screenshot 2025-04-09 at 1.09.19 PM.pngScreenshot 2025-04-09 at 1.09.34 PM.png
Message 8 of 12
Phil.E
Any chance you can share the model? I want to turn this into a more general testing request/bug report for a larger category, something like "face highlighting issues in macos"
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 9 of 12
FrodoLoggins
File attached. Want my diagnostic log files?
Message 10 of 12
Phil.E
Yes, thanks. If you want to send privately just PM me.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 11 of 12
FrodoLoggins
Diagnostic log files attached.
In the below video you'll see me undo a bunch and then redo. When the video starts this face is dark grey:
When the video is done it's the color it should be:
Prior to the start of the video I made 2 cylinders to use as boolean tools. I then used the Combine tool to make them the shape I wanted. Once I moved them up I noticed that dark grey face.
Haven't changed any graphics settings.
Message 12 of 12
FrodoLoggins
Grey started after dissolving an extrude:
Missing faces after hiding a sketch:
Also in the second video nothing is selected but this and only this is underlined in the browser [although that happened prior to setting change 10 times a day every day for like the past 2 years]:
I'm reverting that setting back.
