Copy Paste Bodies - can't resolve warning
juliangall
Message 1 of 46
juliangall
I have a warning in my timeline on a Copy Paste Bodies command. Highlighted yellow as below:
The actual warning says "1 Reference Failures. The model is using cached geometry to solve. Please reselect reference geometry for failed features in the timeline."
However, when I right-click the timeline icon, there is no option to Edit Feature. How do I reselect the reference geometry?
Julian
Replies (45)
Message 21 of 46
stanislav.kanev
(1) QUICK TIP: Redefine Sketch Plane - YouTube - redefining the sketch may fix this issue.
Message 22 of 46
indrekKM3GD
Observer
Observer
This has happened multiple times to me now. How do I fix this? This is taking days out of my life. Instead of doing something useful I'm forced to deal with this garbage by redoing and rechecking everything again and again and again. This is crazy. "There are no plans to fix this" is not a solution. At least place change the warning to "There is no way to fix this. Never use copy on a body in your timeline."
Message 23 of 46
karlNCC8J
As you can see from this thread this isn't a one off issue. I've had to spend many many hours "fixing" my timeline because Fusion allows copy/paste of bodies but then doesn't allow the fix required when the original body changes as described by others in this thread.
@jeff_strater 3 years later, is there an update?
Message 24 of 46
louis.w.hepburn
this happens all the time to me, particularly annoying that it asks you to RESELECT the bodies whilst providing no option to actually do that. this isn't any different to the lack of sketch block functionality they still refuse to add. Useful workflow that they refuse to implement for reasons unknown. fusion is incredibly well geared towards the boolean integration of parts to create new parts, which with the growing demand of 3D printing makes it an ideal choice...until you come across these bizarre decision to neglect these improvements to work flow that completely scuttle the primary purpose of the function.  this problem is only going to increase in its exposure due to the increase desire of tessellating parts/patterns of parts within the demands of 3D printing.  the weird part is we know there is a stored version of the "non-broken" reference, so I don't see any reason why it couldn't be attributed to a different selection with the option to revert between cached vs up-to-date geometry.
Message 25 of 46
bentwookie
Blerg. Nailed by this as well just now. I didn't even copy and paste, but instead I'd forgotten to activate the right component and so I tried to drag a body to the right one to fix the problem once I noticed it (much later). All looked well until I adjusted a parameter (again much later) and the whole thing irretrievably blew up. They should disable copy/paste (and I guess body rehosting) for as many rough edges as there seem to be.
That the warning prompt says you can fix it is an extra punch in the gut right now 🙂
Message 26 of 46
martinYFAFK
@jeff_strater
I'll be retiring in ~29 years, any chance you'll have this fixed by then ? Just asking.
Message 27 of 46
citizenkoen
I'm running into the same problem.
In my case I moved a couple of bodies between two components very early in my history. When I later changed the value of a parameter I ended up with extrusion errors for the two bodies. Somehow, one of the profiles disappeared from the sketch that I used to perform the extrusion. I tracked the problem down to two lines somehow no longer meeting at a corner despite having coincident constraints against the same projected point... That seems to be a bug in and of itself. As soon as I fixed the sketch, Fusion 360 created 2 extra bodies and the copy paste feature lost references to the original two bodies. And now I'm stuck trying to pick up the pieces. I'm 2 hours in and counting...
I see three components to this issue:
1. Clearly there is some underlying bug(s) causing the references to be lost in the first place.
2. The UI misdirects the user by leading them to believe there is a way to fix the issue
3. No mechanism is exposed to allow the user to directly fix the issue
Even if the problem occurs infrequently, which somehow I doubt, it is high impact and stops the user in their tracks when it is encountered. As such, "won't fix" doesn't seem like the right response here.
Message 28 of 46
richard_john3
I just ran into this issue (again). Thought I would just reselect the reference geometry ..... looks like I should just delete and start again from scratch. So, as I understand it, I can not copy and paste a body, ever? It will always blow up like this?
Message 29 of 46
louis.w.hepburn
yep, I have just learned to use and love boundary fill for things where I
would need to copy a body, never use copy unless you are looking to make a
non state changing clone of your model.
Message 30 of 46
jasper_barnett
Community Visitor
Community Visitor
Just ran into this problem & it's gonna cost me multiple hours of work to fix. As others have said, it really shouldn't be that hard to implement an edit feature that allows you to select the body that you're copying. I'm really starting to get fed up with Fusion just not fixing bugs that have been known about for YEARS.
Message 31 of 46
tonynicholls2
I too have this problem. I have copied and pasted several repeated bodies and need to trim them to conform to the profile I needed. I created an offset plane, split the bodies and was presented with this error when I tried to remove the unwanted portions. Previous replies suggest that each of the repeated bodies should be created individually. Surely this can't be right? A previous split and remove worked correctly.
Message 32 of 46
g-andresen
please show in a screencast what you want to achieve
and share the file
File > export > save as f3d on local drive  > attach to post.
günther
Message 33 of 46
louis.w.hepburn
Anderson there is more than enough info on this post to express the exact problem including screenshots, this is a fundamental issue with the workflow of fusion and not something anyone here has done, the lack of post reference options for selecting broken links when making changes to source body is a known issue. in reality, the copy bodies should probably just removed as a tool until this is fixed, such that people don't use it for the purposes of what it pretends to be, a copy of the source body. when really it's actually more of an "export of the source body at that time" with no means of reflecting actual edits made before the body was made, which flys in the face of the whole point of having a history tree.
the true workaround is to use a boundary fill selecting the source body as both the tool and the cell, this has the actual desired effect of what people will naturally presume copy bodies are. I'm certain 10,000 of hours have been wasted by this one oversite and the subsequent lack of fix. i myself lot some 50 hours of work when I later needed to update a selection of projects that featured this issue before I knew it was in fact an issue.
Copy bodies are in reality only useful for the purposes of saving the body at that current time indifferent to edits made to any design history up to that point or for the people who are very, very confident they will never need to make such edits.
the fact that people are still suffering this problem, that is falling into what is essentially a "landmine" programmed in, is really rather telling.
it should either be removed as a tool (given that its functionality is better achieved through boundary fill) or fixed or updated to clearly represent what it actually does.
I'd bet your job this is still like this for yet more years to come, and given the lack of progress on so many fundamental issues you'd be a fool not to as well. what a strange place to work.
Message 34 of 46
tonynicholls2
A suggestion. Since Copy/paste is problematic, why not direct the copy routine to the Boundary Fill routine and avoid the problems that result?
Message 35 of 46
tonynicholls2
I have resolved the issue by redrawing the bodies and using Boundary Fill to copy them before using the Split body tool.. I think the Copy/Paste issue needs addressing though.
Message 36 of 46
kasparRZBHR
Community Visitor
Community Visitor
Developers, please fix!
Step to reproduce with your very own Utility Knife sample model:
1. Open file
2. Edit Split 1 or Split 2 (before the copy/paste bodies) feature and klick OK
3. Fusion renames the resulting bodies from Body 2, 3 to Body 1(1) and 1(2)
4. Copy/Paste bodies breaks and asks the impossible: "Please reselect reference geometry for failed features..."
Message 37 of 46
jrudder91
Community Visitor
Community Visitor
5 years later. no fix :C
Message 38 of 46
rdd.usa
Running into this today. Gonna cost me time to fix. Why can't we just say "delete the lost geometry" (like we do with sketches: delete the lost projections). Dumb!
Message 39 of 46
clintonefisher
Observer
Observer
Paying subscriber here.  Just ran into this defect today.  YES, I will call it a defect, first because the behavior is inconsistent with other features that allow fixing dependencies by re-selecting objects.  Second, and this is the most egregious, is the error message suggesting that it is EVEN POSSIBLE to re-select copied bodies!   C'mon Autodesk.  The price I pay for this subscription commands a fix.  If not for the re-selection omission itself, but to, AT THE MINIMUM, PLEASE CLARIFY THE ERROR MESSAGE TO NOT GIVE FALSE HOPE!  It's flat-out CRUEL to someone running into this problem for the first time.
Message 40 of 46
kellervater
Observer
Observer
nice... also ran into this now.
very dissapointing to see, that this is around for so long and not being acknowledged as a bug.
The least I'd like to see is the message "Please reselect reference geometry" getting removed to not create false hope where there's none.
