Can't select more than one curve to offset
andySZVBN
andySZVBN
I am trying to select and offset multiple curves. Fusion won't let me do so. I'm trying follow this instructional video where the guy clearly can do the selection. What am I doing wrong?
https://www.youtube.com/watch?v=jQ6LQBFZXmU
(at 9:23 the guy select 3 curves and offsets them)
jeff_strater
first, make sure "chain selection" is turned on:
second, make sure your sketch lines are actually connected.  No white dots between endpoints, all in the same sketch (the active sketch).
Jeff Strater
Engineering Director
andySZVBN
Thank you that was the problem
