Copied assembly drawing
linas
Message 1 of 9
linas
Hello!
I was trying to copy an assembly (with included drawings) and the copied drawing is corrupted; It happens to me everytime i try to copy an assembly with its drawings, it is a very useful feature and i need help!
Replies (8)
Message 2 of 9
bhavani_sankuratri
Hi @linas ,
I wanted to check in and see if you still needed assistance, or if you found a solution to your question already? Let us know if you need further assistance by providing an update or if you have found a solution, please share it with the community so other members who may have the same question could learn from your experience.
Bhavani Sankuratri | Community Manager
Message 3 of 9
linas
Hello @bhavani_sankuratri !
Yes, i tried a little experiment and found out if i copy the assembly with drawings included, without changing any components the drawing is fine and working, but if I replace the new copied assembly with components then the problem persists. Because in my workflow I have bunch of similar assemblies (lightboxes for retail ads) but different dimensions. It's more time-efficient for me to copy the assemblies (with drawings included) and then replace the components in my new copied assembly. That way i have similar layout of the drawings and i don't need to redraw. I hope you understand what i'm trying to achieve here and i remember this workflow used to work before the major updates with part/assembly/hybrid design types (i might be wrong though 😄 )
Thank you!
Message 4 of 9
ColeKGRRM
I am recently experiencing this problem. When I copy an assembly with drawings and then try to open to copied drawing, it says its corrupted. This is before I even change anything in the copied model. PLEASE HELPPPPP
Message 5 of 9
ColeKGRRM
Also everytime I make a copy with drawings the copied drawing only links back to the original model and not the copied model. I feel like this not how it should be
Message 6 of 9
linas
@ColeKGRRM yeah now i tried it also to copy the assembly (without changing components) and open the new drawing it says its still corrupted 😞
If you have a new copied assembly with linked components inside of it, naturally it will be linked to old components, but you can replace them
If you have unlinked components inside your assembly, i think it should be new components, but i can't check in the drawings because its corrupted 😄
Message 7 of 9
ColeKGRRM
@linas I found I can open the corrupted drawing if the original drawing I copied is opened. But the copied drawing still links to the original model and not the copied model, which I do not believe this is how the "copy with drawings" feature worked before. It still doesn't help that you can't just open the drawing directly
Message 8 of 9
RajkumarIlanchelian
@mohammed.aliTDPXK Adam, would you be able to look into what could be happening here, please?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 9 of 9
ColeKGRRM
I do believe I have no more issues with copied drawings, but not sure if the original issue got resolved.
