construction plane from current view?
graynak
Message 1 of 10
graynak
is there a way to generate a construction plane based on the current view within the viewport?
a simple example is that we scan tubular vehicle chassis for retrofitting parts
i can manipulate the view to a position that 'feels' orthogonal to the tube-section at a particular area ...
i then want to create a sketch at that one exact view for brackets or collars
i know i can name that particular view ... but i can't then go in and create a plane from it
i think i can do some of that manipulation in mesh-mode with points on three-planes ... but that requires not capturing history ... which destroys all previous work.
thanks!
Replies (9)
Message 2 of 10
g-andresen
Please share an appropriate file with a hint where the layer should be located.
File > export > save as f3d on local drive  > attach it to the next post.
günther
Message 3 of 10
jeff_strater
"is there a way to generate a construction plane based on the current view within the viewport?"
No, there is no way to do that.  There should not be any view-dependent operations in a parametric design.  Viewing operations are considered to be graphics-only operations, and do not affect the creation of geometry or features
Jeff Strater
Engineering Director
Message 4 of 10
graynak
Thanks Jeff S.
I appreciate that rigor in full parametric design.
I am often straddling the parametric universe and the cold hard steel of less-than-perfect real-life fabrication.
It would be nice to cheat every now and then with the feature described above.
I remember having it in Rhino when I was using that a hundred years ago.
Anyway .. my current method starts at the very beginning with a raw mesh and actually setting real orthogonal planes in the mesh.
The issue is that going back into that raw mesh ... and making adjustments using 'a plane from three points'  requires destroying the files history.
thanks anyway ...
i'll continue to use the intersecting-planes-to-create-an-axis method
geoff
Message 5 of 10
g-andresen
I would just like to note that possible solutions will not be given as long as an exemplary sample file for analysis is missing.
günther
Message 6 of 10
graynak
Thanks Gunther
Unfortunately ... the files are 100+ MB ... since the meshes are big ...
but here are a few screen grabs to give the idea:
as i zoom into a cross section of the lower chassis tube of this scan ...
i can position my view in a way that i can 'guess' at what would be the most orthogonal view to the tube
then ... if i could put a plane on that view ...  i could then make a three-point circle and reverse-engineer the chassis tubing
thanks
Message 7 of 10
pavel_viktorin
Hi, I've written a script that, after selecting a point on the model, creates a construction plane at that point, oriented according to the viewport.
Here's how it works:
  • You must be in the design environment
  • Run the script
  • Select the point
  • Construction plane is created
import adsk.core, adsk.fusion, traceback
def run(context):
    app = adsk.core.Application.get()
    ui = app.userInterface
    design = adsk.fusion.Design.cast(app.activeProduct)
    view = app.activeViewport
    def center_view_on_point(point):
        cam = view.camera
        offset = adsk.core.Vector3D.create(
            point.x - cam.target.x,
            point.y - cam.target.y,
            point.z - cam.target.z
        new_eye = cam.eye.copy()
        new_eye.translateBy(offset)
        new_target = cam.target.copy()
        new_target.translateBy(offset)
        cam.eye = new_eye
        cam.target = new_target
        cam.isFitView = False
        view.camera = cam
        view.refresh()
    def create_plane():
        rootComp = design.rootComponent
        camera = app.activeViewport.camera
        cam_eye = camera.eye
        sketches = rootComp.sketches
        sketch3D = sketches.add(rootComp.xYConstructionPlane)
        sketchLines = sketch3D.sketchCurves.sketchLines
        vector = adsk.core.Vector3D.create(
                    cam_eye.x - point_of_interest.x,
                    cam_eye.y - point_of_interest.y,
                    cam_eye.z - point_of_interest.z
        vector.normalize()
        # construction plane scale
        scale_factor = 10.0
        vector.scaleBy(scale_factor)
        transformed_point = adsk.core.Point3D.create(
            point_of_interest.x + vector.x,
            point_of_interest.y + vector.y,
            point_of_interest.z + vector.z
        line = sketchLines.addByTwoPoints(transformed_point, point_of_interest)
        planes = rootComp.constructionPlanes
        planeInput = planes.createInput()
        distance = adsk.core.ValueInput.createByReal(1)
        planeInput.setByDistanceOnPath(line, distance)
        construction_plane = planes.add(planeInput)
        construction_plane.name = "Plane from view"
        sketch3D.name = "plane sketch"
        sketch3D.isVisible = False
    if not design:
        ui.messageBox('You need to be in the design workspace')
        return
    ui.messageBox('Select a point on the model.')
    selection = ui.selectEntity('Select a point on the model.', 'Vertices,ConstructionPoints')
    if not selection:
        ui.messageBox('No point was selected.')
        return
    selected_point = selection.entity.geometry
    point_of_interest = adsk.core.Point3D.create(selected_point.x, selected_point.y, selected_point.z)
    center_view_on_point(point_of_interest)
    create_plane()
Message 8 of 10
elrico_cattaneo
Community Visitor
Community Visitor
You beautiful person, I can not believe you have come back in here 3 years later to solve this. This works brilliantly thank you so, so much.
Message 9 of 10
HughesTooling
thanks!
Just in case it's helpful to someone you can create a three point plane in direct edit mode without losing history.
Mark Hughes
Owner, Hughes Tooling
Message 10 of 10
Mr_8hz
Hi
How to add that script text?
Thanks!
