Construction Folder Missing from Browser
bjarolimHEWRQ
bjarolimHEWRQ
My construction folder is missing from my browser for one specific design I've been working on. I have tried resetting to default layout with no results. I have not found anyone else with this issue in my research. Any help is appreciated.
julia.paganucci
Autodesk Support
Autodesk Support
Hi @bjarolimHEWRQ ,
Thanks for posting! If you construct an offset plane or axis (any type that's constructed), does the folder then appear?
Julia Paganucci
Technical Support Specialist
| Autodesk Knowledge Network | My Screencasts | Fusion 360 Webinars | Tips and Best Practices
bjarolimHEWRQ
I get the following warning.
Warning: The object that you are creating is not visible. Please toggle visibility in the browser.
I do not have a construction folder to toggle...
julia.paganucci
Autodesk Support
Autodesk Support
HI @bjarolimHEWRQ ,
That's strange... If resetting the default layout still doesn't work, I would perform a clean uninstall using the Fusion cleaner tool and reinstall.
Let me know if that fixes it. Thanks,
Julia Paganucci
bjarolimHEWRQ
I was trying to avoid that, but I'll give it a shot once I check my home PC for the same issue.
julia.paganucci
Autodesk Support
Autodesk Support
Hi @bjarolimHEWRQ ,
I also noticed that you have in invisible component. If you open up this component, does it have a construction folder? It doesn't look like this component is active, but if it is it could explain the error.
Julia Paganucci
bjarolimHEWRQ
I tried making everything visible yesterday and looking through all the folders. I also reinstalled today with no luck. I did however find a solution.
I inserted that design into a new design. I then broke the link and created a new construction plane and Voila! My construction folder is back, but oddly only has the newly created plane. I suppose this will work for me, at least I can see new planes now.
