Constraint on user parameters
enrico_soldaHT542
Message 1 of 8
enrico_soldaHT542
I'd like to know an easy way to define and maintain constraints on user defined value. For instance define interval of validity on user parameters or inequality related conditions. I guess is not that straightforward in current user parameter definition process. Is there any good clue?
Regards
Replies (7)
Message 2 of 8
TheCADWhisperer
@enrico_soldaHT542
In Autodesk Inventor Professional you can set Limits (Range) or a List of discrete values for a Parameter.
Message 3 of 8
enrico_soldaHT542
Thank you a lot for your prompt reply!
I was writing for Fusion 360 board unfortunately! That just means that my doubt is meaningful, at least ;D
Maybe there's something similar in fusion 360? Let me know.
Best regards.
Message 4 of 8
TheCADWhisperer
@enrico_soldaHT542
I don’t know of a way to do this in Fusion 360.
Are you a student?
Message 5 of 8
enrico_soldaHT542
Yes, I'm. Indeed I'm using an educational version so I don't know if there is any additional tool or feature allowing such functionalities, would be much useful. I was thinking theoretically is possible to use some expression and formula in fusion 360, would in case do similar job, but are much more work taking and difficult to write and maintain, and absolutely terrible to read. So I want to avoid that option.
Message 6 of 8
TheCADWhisperer
@enrico_soldaHT542
Students can get Autodesk Inventor Professional for free.
Message 7 of 8
enrico_soldaHT542
Ok, thank you for informing, I'll consider it soon, but now my project priorities tie me on Fusion 360.
Message 8 of 8
enrico_soldaHT542
Ok, thank you for informing. Currently I'm compelled using Fusion 360, but after this job I'll for sure take advantage of this option.
Regards.
