Confused about fully featured hubs
Bjanders
Bjanders
I have a notification that I have to move to fully featured hubs.
I have previously moved all my Single User storage projects to a hub, and I'm only using my hub:
I clicked "Start" in the notification, but couldn't see my own hub:
Going on a tangent, In the dialog above I see others that have the same email domain as me, iki.fi, which is just a generic domain, like gmail.com. Should I really see the email addresses of other subscribers that I have nothing to do with?
But the real question: Do I have to create a new Team, although I already have a Hub?
I did read https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Single-Storage-is-... but that just talks about upgrading to a Hub, which I already have done. Maybe I missed or didn't understand something? Is a Team and Hub two different concepts? The document does not mention "Team" a single time, just "Hub", even though the article URL has "Team" in it.
praise.tomWX9P2
Hi @Bjanders
If you already have a team hub no need to create new one. Please select the right team hub and click on next. This will move all the projects from personal hub to your fusion team hub. There is no difference between the team and hub, it meant Fusion team hub.
Regards
Praise
Praise Tom
Bjanders
Thanks for your reply. I think you need to clarify your terminology. So there is Single Usage Storage, Personal Hub and Team Hub? Currently I only have a Personal Hub and need to create a Team Hub? I haven't yet seen any documentation where you make the distinction between Personal and Team Hub. For example, the document I linked above just talks about "Fusion Hub" and only about transferring from Single User Storage to "Team Hub".
"Fully featured hub" is the same thing as a "Team hub"? And a "personal hub" is a non-fully featured hub? Please just use one term across the board, and don't use interchangeably "Fusion Hub", "Team Hub", "Fully featured hub" if those all are the same thing.
praise.tomWX9P2
Thank you for your response. Sorry for the confusion here.
Personal hub and/or single user storage hub are same which are non fully featured hub. Fully featured hub means Fusion team hub (Team hub/fusion hub). Single user storage (personal hub) is a legacy storage hub. I hope this helps you for better clarity.
Praise Tom
Bjanders
(Deleted message, changed to response to praise.tomWX9P2.)
Bjanders
Thanks for the clarification. In the screenshot in my first post you can see from the "Hub" icon that I'm using "Fusion team hub" and not "Single User Storage" which has a different icon (a person). So I don't need to do anything, right, and I can ignore the warning? I have already moved my projects from "Single User Storage" to a hub months ago.
praise.tomWX9P2
Hi @Bjanders
Can you please share your email address of Fusion account with me (please send it direct message). I will check and update you.
Praise Tom
