Command "Move to group" is not working correcty
martin.konarsky
martin.konarsky
When I use command "Move to group" it will not move bodies to another group (component), It will copy them, so I have everything twice.
I use this command to sort out the bodies from imported files with one component. I create components with names and sort the bodies what is what, etc. steel structure, machinery, foundation ..... I do it always this way and suddenly it is not working.
thanks for support
jeff_strater
Can you clarify your workflow here?  Move to Group is not intended to move bodies from one component to another, it is used to move bodies into a folder within the same component, as a way to organize your Bodies folder within that component.  Are you trying to move bodies from one component to another?
Jeff Strater
Engineering Director
martin.konarsky
I looks like software issue, after update it is again OK.
