I have a repeatable issue with patterning features:
1) I use Loft w/ Cut to create a radial hole in a cylinder
2) I use circular pattern to pattern the loft/cut feature.
3) The result is not an array of radial cuts. Pattern creates new attached solids in the profiles of the loft uses for the cut.
I tried a couple settings, but could not get this to work. Any thoughts?
I made a little video of the issue on a trivial part:
The Strange result, not circular pattern of cuts:
