Unable to create New Component in New Project - Fusion 2605.1.18
paulbarton73
Message 1 of 8
paulbarton73
I've run into a really frustrating issue; when I create a New Project I cannot make a New Component. The icon has gone from the Create dropdown and from the right-click menu in the browser tree. Am I being thick here?
I'm using version 2605.1.18 on Windows 11 Pro and have a full subscription.
This post has been edited due to: @heather_tracy added the product and product version to the title to help more users find this topic via external search.
Replies (7)
Message 2 of 8
Richard.stubley
Hi Paul, have you turned on the preview of Intent Driven Design?
Richard Stubley
Product Manager - Fusion Mechanical Design
Message 3 of 8
paulbarton73
Hi Richard,
I do have a few preview features on but not Intent Driven Design.
Message 4 of 8
Richard.stubley
Hmm, maybe the assembly Tab UI preview. Could you send over a screenshot of the Design preview features you have on.
Also just to check when you start a new document you don't see the "what do you want to create" dialog?
https://www.autodesk.com/products/fusion-360/blog/intent-driven-design/https://www.autodesk.com/products/fusion-360/blog/intent-driven-design/
Richard Stubley
Message 5 of 8
arjun_pillaiZCXQN
Hi @paulbarton73 ,
There should be a Block called "Assemble" on the ribbon with the "intent driven feature" feature off , The "new component" is moved under that. I have attached a screenshot with an arrow pointing to the new component logo.
This is a screenshot of the ribbon of 2605.1.39 version, with the "intent driven design" feature off.
Hope this helps!
If my answer helped, please 'Accept Solution'
Arjun Pillai
Quality Assurance
Autodesk, Inc.
Message 6 of 8
paulbarton73
Hi Richard,
'New Component' tool is now visible but only imder the Assembly Tab and not available under the Solids tab.
Hope this helps
Message 7 of 8
paulbarton73
Hi Arjun,
Hope this helps
Message 8 of 8
Richard.stubley
Perfect, that makes more sense.
With the new experiences.
Part : New component not available, this is by design
Assemblies : New component is in Create
Hybrid : Currently it's in the Assembly tab, It will come back to Create in the Solid tab when you are in Hybrid. It just wasn't in time for this preview.
Hope that helps.
Richard Stubley
