Circular Patterning of Cut features not working as expected
DavePlant
DavePlant
I have a repeatable issue with patterning features:
1) I use Loft w/ Cut  to create a radial hole in a cylinder
2) I use circular pattern to pattern the loft/cut feature.
3) The result is not an array of radial cuts. Pattern creates new attached solids in the profiles of the loft uses for the cut.
I tried a couple settings, but could not get this to work. Any thoughts?
I made a little video of the issue on a trivial part:
(view in My Videos)
The Strange result, not circular pattern of cuts:
a.laasW8M6T
That is odd, but changing the compute type to optimized works
Andrew Laas
Senior Machinist, Scott Automation
rosie_lucas1
Hello @DavePlant,
Did the information provided by @a.laasW8M6T help you and answer your question?
If yes, please click on the "Accept Solution" button on the post(s) that solved your problem. This will assist other community users in finding and benefiting from this information.
If not, please do not hesitate to give an update in this thread so all community members receive an update on the progression of your question, and can suggest next steps that may be helpful for you to achieve what you're looking for.
All the best,
Rosie | Community Manager
g-andresen
For patterns, it is advisable to test options other than Identical.
In this case, in addition to Optimized, Adjust and Object type “Faces” also work.
(view in My Videos)
günther
