Change after mirror
Change after mirror
mcjj29909
Message 1 of 8
Change after mirror
mcjj29909
New user here.
Test #1
1 - I created a body
2 - I created a plane
3 - I mirrored the body
4 - I altered the original - rounded a corner
The mirror body did not change
https://autode.sk/37lLNWl
Test #2
1 - I created a sketch
2 - I created a mirror axis
3 - I mirrored the skecth
    a - changed circle size
    b - rounded a corner
4a -The mirrored sketch (circle) correctly changed
4b - The mirrored sketch (corner) did not change
https://autode.sk/3cWNdYC
What is going on??
Thanks in advance for any help
Jay
Replies (7)
Message 2 of 8
TheCADWhisperer
First problem.
History.
Move the Fillet feature to before the Mirror feature.
(Also the workplane isn't technically needed.)
Second problem.
History again.
Message 3 of 8
mcjj29909
Thanks for your answer - the object was to use the 'built-in' change feature
of mirror where a modification to the original will telegraph to the
mirrored 'copy'.
Jay
Message 4 of 8
TheCADWhisperer
I understand the objective - I don't think you understood my response.
File>Export and Attach your *.f3d file here.
Fusion follows a history-based parent/child relationship.
It's all in the Timeline.
Message 5 of 8
mcjj29909
I'm pretty sure I understood: Put the changes before the mirror therefore any of the changes will be part of the mirror operation.
However, that negates the benefit of automatic changes.
Please see files attached as requested
jay
Message 6 of 8
TheCADWhisperer
Can't defy logic.
Video to follow....
Message 7 of 8
mcjj29909
Thanks, Awaiting video
Jay
Message 8 of 8
TheCADWhisperer
Oops, made the video and then forgot about it while it was compiling.
History
in history timeline you Mirrored Feature rather than body and selected the specific feature that you wanted to mirror.
Then later in time, which logically Mirror could not anticipate what you would do later in time, you added a fillet.
So logically,
in history you would need to add the Fillet before mirror and then Edit the Mirror to tell it, oh by the way, I also want to mirror the Fillet feature
or
change the Mirror to mirror of Body rather than Feature and move the feature to before Mirror so that in time Mirror knows that Fillet exists.
With sketch you only have one choice - edit mirror and add the additional entity.
In a history-based modeler like Fusion, SolidWorks, Inventor, Creo - this all follows a very logical process.
