chamfer-error when selecting from sketch palette
Tomas_V_cz
Tomas_V_cz
I think the chamfer  tool is not working properly when selected from the sketch pallet - the selection is not reflected in the sketch:
Maybe the pictures will be clearer:
If I select the distance and angle changer option from the menu as shown in the image, the tool works fine.a.png
if I select the distance and angle changer option from the sketch pallet, switching between the 3 options does not work
sorry for my english
dsouzasujay
Hi @Tomas_V_cz
This is clearly a bug. I created internally FUS-213960 to track it.
As a workaround, please access the command directly through
  • 'Modify' --> 'Chamfer' --> "Distance and Angle Chamfer"
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
