Canvas imports with wrong aspect ratio
greenveg
Message 1 of 41
greenveg
As title says, canvas import results in a completely wrong aspect ration witch also makes the function kind of useless.
Here I am trying to make a quick wall mount for my drills.
Image fileImage fileScreenprint from import screenScreenprint from import screenSkärmavbild 2019-12-10 kl. 15.34.37.png
Replies (40)
Message 21 of 41
tomsaubi
@TrippyLighting wrote:
@tomsaubi I do understand those concerns and at some point in time had the same thoughts. However, I use a number of other CAD products and have found and reported bugs there as well.
Think I missed this the first time round. Seems to answer my question about other software having issues too. Seems to come with the CAD territory then. I'll try to stop being so hard on fusion! 👍
Message 22 of 41
alphaaPDYTU
Observer
Observer
Simple fix, crop the photo into SQURE, where width and length are exactly the same.
import it, it will work.
I suspect fusion 360 has mixed up the X and Y.
and to be honest... fusion... this is a know problem for years.... fix it since you are now collecting millions from users all over the world, come on.
Message 23 of 41
acrR6J3R
Still Broken.
Message 24 of 41
OceanHydroAU
This is a known bug - remove the image metadata to fix it.
Message 25 of 41
tdfguy
Observer
Observer
Even though this is an old thread, the tip to crop the photo on the iPhone works well!  Thank you!
Message 26 of 41
adamdport
@OceanHydroAU "known bug" or not, it's THIS thread that popped up for me when searching for the issue. Your work-around worked for me, thank you.
Message 27 of 41
robertKAEVY
Community Visitor
Community Visitor
This bug is still occurring in 2025, it can still be fixed by slightly cropping the image before importing into Fusion.
Message 28 of 41
tom.trecek
This bug requires like 5 mins coding to fix, and it's still there 6 years after being reported. Bravo, Autodesk, bravo.
Message 29 of 41
tom.trecek
Btw the issue happens when you take picture with your phone vertically. I guess it's then marked in metadata that width and height have to be switched. Unblievable Autodesk didn't figure this out in 6 years.
Message 30 of 41
timmarkut2799
Community Visitor
Community Visitor
Just wasted the better part of 40 minutes because of this bug. Can confirm that cropping the image first fixes it.
Message 31 of 41
nikhil_hase
Workaround: Convert the JPG picture to a PNG and insert it in Canvas.
Please try with the above workaround.
Message 32 of 41
luka_flerin455TQ
Community Visitor
Community Visitor
Helo this bug is still occurring in 2026. Shame on you autodesk.
I try delete all data from picture, convert to .png and add picture to paint and save it still the same.
Message 33 of 41
TheCADWhisperer
@luka_flerin455TQ
Attach image file that exhibits this behavior.
Message 34 of 41
g-andresen
The cause is an image from a source such as a smartphone that does not provide “format data.”
An easy remedy is to open the image in an image editing program and save it as a png or jpeg without editing it.
günther
Message 35 of 41
tom.trecek
Any other programcan deal with images from phone just fine, and display them in correct orientation. So the necessary data is there. Only AUtodesk can't read it properly and instead of fixing it, lies about "not having format data"... If the data is not there, how come any other program displays it in correct orientation??
Message 36 of 41
TheCADWhisperer
@tom.trecek
Can you Attach an image here that exhibits this behavior?
Message 37 of 41
tom.trecek
Sorry, but when autodesk people say "it's because the picture is from mobile", it shouldn't be so hard for the devs to actually take picture by mobile themselves? I just took a picture in portrait, all programs shows it as portrait, only F360 shows it as ladscape (=wider).
Message 38 of 41
TheCADWhisperer
@tom.trecek
Shift Win S
Save
Canvas
About 3 seconds.
Message 39 of 41
tom.trecek
It's not about the 3 seconds. It's about it being imported wrongly. For YEARS. And instead o fixing it, you're telling customers to do workaround each time... Why can't it be imported correctly in the first place? Imagine window in your car can't open, so you go to the dealer to fix it. And he says - just open the whole door, see, 3 seconds....
Message 40 of 41
nikhil_hase
@tom.trecek ,
Sorry for inconvenience , We are expecting this to resolve in March release.
