Cannot save file due to reference a local file that does not exist
bt22831
Observer Observer
bt22831
Observer
Observer
When i try and save a file it comes up with this error message- "Error: [CFS] Save of the cloud file Solar Array Assembly v5 is aborted because it is referencing a local file Battery bottom layer v0".   I have checked that the file is not saved locally on my laptop or on anyone's in my team. I cannot even find the file on the cloud. What should I do?
RajkumarIlanchelian
@bt22831 Here is an article that can help solve for this - https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Save-of-the-cloud-...
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
bt22831
Observer
Observer
Ok so I just forced quit like the article says and then went to open the recover document only to find that fusion did not create a recover document. So I have just lost everything. Does anyone know a way to retrieve the file even if no recover document was made? Is that possible?
jhackney1972
It depends on your save conditions but you may find it in this folder on a Windows based computer.
C:\Users\<username>\AppData\Local\Autodesk\Autodesk Fusion 360\RVBZRQQ6M5D3\W.login\F
John Hackney, Retired
