Cannot create Tangent Relationship due to multifaced surface
wallyanalogtools
wallyanalogtools
I have successfully used Tangent Relationship in the past to show how a stylus interacts for an animation with a sinewave-type like surface. That surface was extruded from a single sinewave line in sketch. I now need to make a more complex (read: distorted) sinewave and can only do this by linking multiple curves and lines together to form the line/curve segment that can then be extruded into a body or surface to interact with my stylus body in an animation. Unfortunately, the face of the body is multi-faced because of the many line/curve segments that created this. As a result, I cannot get a tangential relationship to form between the stylus and ALL of the faces of the body.  How to make the body from a single, continuous face rather than many faces? Thank you for any help you can provide. See attached photos
g-andresen
Please share the file.
File > export > save as f3d on local drive  > attach it to the post
günther
wallyanalogtools
Here you go! Thank you.
jhackney1972
See if the attached model, Body 24, will fit your requirements.
John Hackney, Retired
wallyanalogtools
That looks great. Thank you! How did you do that?
wallyanalogtools
jhackney1972
The process I used is outlined in this Blog Article and Video.  The sketch I started with was a projected sketch from your model profile.
