cannot assign diameter or radius dimension to notched circle.
jorgegZGUPV
Message 1 of 8
jorgegZGUPV
trying to add a diameter dimension to a circle with notches and fusion does not recognize the edge of the circle to input dimension.
Replies (7)
Message 2 of 8
TheCADWhisperer
Message 3 of 8
jhackney1972
I hope I understand the feature in question.  Do not use Automatic Dimensions, choose Diameter dimension from menu list.  By the way, a Radius dimension is preferrable in this instance.
John Hackney, Retired
Message 4 of 8
jorgegZGUPV
no, the diameter of the big circle. your example shows a square and are measuring the radius of the slot.
I want to dimension the diameter of the OD of the wheel and neither diameter or radius recognize the edge of the wheel.
Message 5 of 8
jhackney1972
You do the same technique to get the diameter dimension on the OD for the notched circular component.
Message 6 of 8
TheCADWhisperer
Message 7 of 8
jorgegZGUPV
that exactly what i am tying to do, but the software does not let me choose the OD of the wheel to dimension it, in my drawing.
do i need to re-install the software to get it to work?
Message 8 of 8
TheCADWhisperer
