How do I post the the Feedback Hub forum? There's no button to create a new post.
Hey SGoldthwaite,
Ryan is right, the Feedback Hub is structured so that only product managers and researchers can create posts. That said, there are (or will soon be) posts soliciting general feedback in different categories (Sktech, Model, Simulation, etc.), so any general feedback you have can be posted there.
What kind of feedback are you looking to give? If you can explain the basics I can find the right place for it or push for a new general feedback request in the appropriate category.
I posted a couple suggestions already regarding the Change Parameter dialog box and being able and dependent parameters:
https://forums.autodesk.com/t5/fusion-360-ideastation/find-dependent-dimension/idi-p/9101611
Also, the Mac post processor dialog box (in Manufacture workspace) is a lot different then Windows - I use both. I'd like to see the Mac be more like the Windows one. Also, an easy change would be to make the Mac dialog box wider. Some of my posts processors have similar descriptions and it's hard to tell the difference in the list because the narrow dialog box doesn't show enough info.
So how do I submit an improvement/feature to fusion 360? I have spent 20 minutes to attempt it and no luck, seems feedback hub is locked down. Anyone have a link?
@Anonymous A link won't change much but I'd suggest reaching out to an employee and they'll either take on your idea or link you to somewhere suitable.
