Can't install Fusion 360 - SSL Certificate verification failed
carlHDY6H
Message 1 of 25
carlHDY6H
Tried it numerous times on different networks. Turned off my virus scanning but still having problems.
[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: self-signed certificate in certificate chain (_ssl:c:1000)
Attached is the error log.
Replies (24)
Message 21 of 25
carlHDY6H
Hey rezakazemi. I gave up and went elsewhere to other software.
Message 22 of 25
j_dolieslaeger
Community Visitor
Community Visitor
I am having the exact same issue. Tried all of the above, but to no avail.
Clean installed macbook, wanted to install Fusion and got into the same error.
Message 23 of 25
RajkumarIlanchelian
@j_dolieslaeger Can you please collect the logs and attach here?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 24 of 25
j_dolieslaeger
Community Visitor
Community Visitor
Message 25 of 25
RajkumarIlanchelian
@j_dolieslaeger Our engineering team has confirmed with the logs that it is the firewall/proxy of likely your company that is blocking the install.
Here are a couple of articles that will help
https://www.autodesk.com/support/technical/article/How-to-configure-a-proxy-server-or-firewall-on-Ma... or https://www.autodesk.com/support/technical/article/Configuring-anti-virus-software-for-use-with-Fusi... might help as well
Autodesk Fusion
Join Fusion Insider
